Line render options
| Command | Path |
| Line Render Options | View > Rendering |
Use the line render options to control the appearance of lines in Hidden Line, Dashed Hidden Line, and Final Shaded Polygon modes. These settings apply only to the current drawing; they remain in effect in the current drawing until the settings are changed. The current line render settings are saved when you create a template (see Concept: Templates).
To set line rendering options:
Select the command. The Line Render Options dialog box opens, set the parameters.
| Parameter | Description |
| Dash Style | Select the dash style for hidden lines when the Dashed Hidden Line mode is selected |
| Dash Shade | Adjust the slider to select how hidden lines are shaded when the Dashed Hidden Line mode is selected |
| Preview | Displays a preview of the selected parameters |
| Smoothing Angle | Sets the angle to reduce facet lines when the Hidden Line, Dashed Hidden Line, or Final Shaded Polygon mode is selected; if the value is greater than zero, facet lines will be removed between any two faces of an object that are within that angle of each other
| Generate Intersecting Lines | Generates lines where surfaces in the drawing intersect each other when the Hidden Line, Dashed Hidden Line, or Final Shaded Polygon mode is selected; for large files with a lot of curved surfaces, this option can make rendering slower
| Display Surface Hatches | Displays surface hatches in a hidden line rendered view
| Display Text and Markers | Displays text and markers in the rendered view. Hiding text and markers can significantly decrease rendering times. |
| Sketch Hidden Line Results (Design Suite product required) | Specifies whether to apply sketch effects to lines when the Hidden Line, Dashed Hidden Line, or Final Shaded Polygon mode is selected; see Sketch rendering |
| Document Default Sketch Style (Design Suite product required) | Sets the default sketch style for lines when the Hidden Line, Dashed Hidden Line, or Final Shaded Polygon mode is selected; see Sketch rendering. Click Edit to open the Sketch Style Editor dialog box for additional sketch style modification. |
